2.2 oil pans
the 1 in my car now is the Z shape pick up and pan has that small area where the pickup sits and the problem is the pan i want to use looks more like a 2.5 pan or 89 2.2 pan that i have too bad it don't fit a 87 2.2
Originally posted by "mpbiv"
Now I am confused because the only flat side of my pan is the back, and the front does have a nose shaped bulge right around the oil pump, and the bottom has a very slight "v" shape.
You aint common block. I guess I was forgetting about the NA 2.5s. We were both talking about different things, thinking the other was talking about the same.
Guess I need to stick to giving info out only on NA's
Patrick
05 SRT-4: Daily Driver, 11.9@117.4
88 Aries: 2.2L Turbo (Powered by Megasquirt II)
Patrick
Guest
Posts: n/a
Now if we can get the rest of TR to follow that idea.................. No offence to you, but at least you realize, and are trying to learn unlike the "others"
Guess I need to stick to giving info out only on NA'sAnd yes I am learning, and quickly, PH34R M3
Patrick
Patrick
Guest
Posts: n/a
Yeah unfortunately that will never happen.
:notworthy:
