K is fuxored............again.
Old Aug 19, 2002 | 08:30 AM
mpbiv's Avatar
Rod Bearing Eater
Well the filter was new and the pump is stock from the factory. I have the low pressure (14.5psi) TBI setup. My fuel pressure gauge read 12-13psi all the time. Of course its under the hood so I have never checked it under normal driving conditions.
I am not sure if I have the same pump as the higher pressure TBI's. But if thats the case then I assume the FPR is different between the two and that my pump would probably last longer since it wouldn't have to work as much.
Patrick
05 SRT-4: Daily Driver, 11.9@117.4
88 Aries: 2.2L Turbo (Powered by Megasquirt II)
Old Aug 19, 2002 | 01:05 PM
mpbiv's Avatar
Rod Bearing Eater
GRRRRRRRRRRRRRRR
They said my oil drain plug came out, fuxor POS k car, I am giving up
Patrick
Old Aug 19, 2002 | 02:59 PM
flybyuin2.2's Avatar
sorry to hear that Maurice ,i guess now is the time for a T2 conversion, don't give up
Old Aug 19, 2002 | 06:14 PM
CrazyMoparGirl's Avatar
Guest
T2T2T2T2T2T2T2T2T2T2T2T2T2T2T2T2T2T2T2T2T2T2T2T2T2 T2T2T2T2T2T2T2T2T2
Old Aug 19, 2002 | 06:40 PM
mpbiv's Avatar
Rod Bearing Eater
Patrick
Old Aug 19, 2002 | 06:42 PM
Guest
I know it doesn't grow on trees just the stuff they print it on comes from trees
Old Aug 19, 2002 | 06:51 PM
  #17 (permalink)
leadfootedfool's Avatar
Eat soot
Always cophers special pull days....I'm sure me and j3ff could lend a hand.
Old Aug 19, 2002 | 06:57 PM
  #18 (permalink)
mpbiv's Avatar
Rod Bearing Eater
We'll see what happens if its bad then I might, if its not bad I won't. I pulled over as soon as I saw the smoke and when I stopped I still had oil coming out which leads me to believe I only had run a few secs without pressure. That may have been enough to do it but I am hoping it didn't. Hell I might just get something else. I am tired of working just to fix a car, would rather work to make it faster.
No matter how you put it I will be out of a car for a while. And if I do build a turbo engine for it I will take a lot longer than I did to do my TBI. I think I learned the hard way that I was trying to finish things too quick. If I do drop another engine into this car, it will be nothing short of perfect before I even think to put it on a hoist and lower it in.
Patrick
Old Aug 19, 2002 | 06:59 PM
  #19 (permalink)
mpbiv's Avatar
Rod Bearing Eater
Really????? What is this?????
Might be a good time to get what I need, just have to find a way to get down there.
Patrick
Old Aug 19, 2002 | 07:04 PM
  #20 (permalink)
Guest
It when you pull all you can for a small fee plus core charges, It's how aquired alot of the parts I had, till my Father in Law cleaned my yard grrrrrrrr but that's in the past who needs 440's and # matching drivetrain parts and rear ends and on and on and on
