MauRice's Miscellaneous Thread O Crap
Old Jul 28, 2002 | 09:29 AM
leadfootedfool's Avatar
Eat soot
I knew it, your asshole must be the size of a basketball
Old Jul 28, 2002 | 12:06 PM
CrazyMoparGirl's Avatar
Guest
Originally posted by "FearThe4Doors"
Originally Posted by CrazyMoparGirl
which may cause our trip to Fl to get cancelled
Seriously?
No!!!!!!!!!
My spirit may finally be working!
It is a possibility, we find out on Aug7th how bad his knee is. With his type of injury he might need surgery. All this from bending down to pick up a ball, If it wasn't for bad luck I'd have no luck at all.
Old Jul 28, 2002 | 05:52 PM
mpbiv's Avatar
Rod Bearing Eater
All that damn noise coming from my car is not from the accesories. Going to drop the pan tomarrow and check to make sure everything is kosher, despite the fact that I doubt I will find anything there. Today I found one of my transmission mount bolts missing from its hole. Turns out it worked its way out and was sitting on the dif case, suprised I didn't lose it. I sure hope that didn't fuxor up the torque converter or pump.
Patrick
05 SRT-4: Daily Driver, 11.9@117.4
88 Aries: 2.2L Turbo (Powered by Megasquirt II)
Old Jul 28, 2002 | 06:04 PM
mpbiv's Avatar
Rod Bearing Eater
I already have a leaf blower at home
Patrick
Old Jul 28, 2002 | 06:14 PM
  #17 (permalink)
Guest
Mopars are funny like that. In the convert we have for some weird unknown reason the tranny bellhousing bolts worked loose and caused the flex plate to be ripped to pieces.
Old Jul 28, 2002 | 06:23 PM
  #18 (permalink)
mpbiv's Avatar
Rod Bearing Eater
I just got one of those mechanics stethoscopes so tomarrow I will also see if the noise is from that area. If it is I am going to assume that it is the torque converter, flexplate, or pump. Oh did I mention that the other top bolt, right beside the one that came out, was loose?
Next time I will be drenching them bishes in thread locker. I should have known better.
Patrick
Old Jul 28, 2002 | 06:31 PM
  #19 (permalink)
mpbiv's Avatar
Rod Bearing Eater
So if you guys still decide to come to FL what were the plans? Anything fun?
Patrick
Old Jul 28, 2002 | 06:43 PM
  #20 (permalink)
Guest
moving some more of are cars to our house in z-hills, and drop the kid off for a couple of months. We were going to go to New Orleans for 2 days, but we decided not to do that, Oh well.
We used thread locker and they still loosened up, why I have no clue.
