Bob...
12 is Battery Disconnect
21 is one of three 1) Upstream o2 Voltage shorted to Ground 2) Upstream o2 sensor shorted to Voltage and 3) Upstream o2 sensor slow response.
More detailed info: 1) tested after key off and at start run
2) Upstream O2 sensor input voltage maintained above normal operating range
3) Upstream O2 sensor response slower than min required switching frequency or value does not go above .65v
Baisically replace it IMO
Guest
Posts: n/a
LOL no thanks.. ill let it cool down. Is it able to be changed without a socket? I always used a big wrench on the turbo dodges. I guess I could buy a socket though. Where is the sensor at? Downpipe? by the firewall?
Any clue what they cost? I get 1/3 off at the dealer
We had to borrow Walters O2 socket
Here are the directions straight out of the SM
1) Raise and support Vehicle
2) Unplug Sensor Connector
3) Remove Sensor using crow foot wrench or equivilant
4) After removing sensor the Exhaust Manifold threads must be cleaned with an 18mm x 1.5+6E tap coat new sensor threads with anti-seize.
How to install
1) Install sensor and tighten to 20 ft. lbs
2) Plug sensor to connector
3) lower vehicle.
It is the O2 sensor before the cat closest to the engine. near the exhaust pipe flange.
How to install
3) lower vehicle.
