balance chain??
<<<<< some cars have gone close to 500 hp without breaking the balance shaft chain, but I wouldn't reccommend it to anyone else. I considered myself lucky that it never broke with that much hp. It will save you headache in the future to just go ahead and get it out of there
I made 563whp with the stock block..
Once i built the motor i removed the balance shaft and chain.. big difference! the car will rev quicker...
if you are not planning on going big turbo or anything like that.. I would just leave it alone.. If you just want a faster rev get a clutch with an aluminum flywheel.
Pablo
Pablo
Its true. And people have seen 10-15hp from it.
I don't disbelieve it, but, again; No one has offered any real proof.
"Kid, If you call me 'bro' one more time, I swear to Christ you're going to find out what your left testicle tastes like."
I offer professional computer / network services and consulting.
Over 10 years of industry experience.
A+/Network+/Security+ Certified ; CISCO CCNA, Novell CNA, Microsoft Certified IT Professional.
remove the balance shaft if your aimnig in high power #'s. it is a big and heavy mass on the bottom of the motor. if you do remove it you will be fine but at higher hp #'s you should have the entire rotating assembly balanced by a machine shop to be safe( my old neon had this done) just make sure to block the oil hole or your motor wont get any oil pressure. there not hard to remove and i can see it freeing up a few hp (not sure about 10 but easily 4-5)
I never had an issue not running one. I couldn't even tell after I removed it. I just cut/broke the chain and left all the assembly in there so my oil level on the dip stick stay'd correct.
Its good for 8-12whp depending on what kind of RPM your motor makes power at.
The rotating assembly isn't balenced with the "balence shafts" so removing the chain doesn't do anything to the balence of the motor, its just like removing power steering or an A/C compressor.
86' snapper electric powered lawn mower.
95' F-350 crew-cab powerstroke 5-speed 21.63mpg
03' G35 6-speed coupe. Grey on black.
02' wranlger apex edition with EFI 5.0L 302 SBF. 5.5'' lift, custom 4-link 8.8 in the rear, high pinion D30 front with locker.
A wise man once said, " I didn't wash my hands b/c my D**K is cleaner then ANYTHING, in that bathroom"
