SRT Help
Does anyone know if I can put an SRT bumper, hood, and rear bumper on a 99 Neon without major mods? If so I am looking for all of them just picked up an SRT motor and it is going in very soon.
where'd you get the motor? i can get all the stuff u need from a local shop and yes it all fits right up. PM me when your ready to buy stuff.
they wont fit at all 1999 is still the 1st gen style. if its 2000 and up then yes it will. the srt rims, and seats swap directly but motor/trans take a bit of work (hope you also got the pcm and key/ignition). all of the 2md gen neon parts swap but not with the 1st gen.
what????????????????????? where are you getting your information from? the srt motor wont sork with the stock neon transmission, the motor mounts are all different, the motor wont run without a flashed ecu to the key that has a micro chip in it unless you run a standalone. body parts arent even close.
Base 4D, 2.4L swap, 2.0 cams, SRT turbo, 52mm TB, gauges and 3.0 unmodded intake, BOOGERS! and Megasquirt! 250Hp to the ground.
Base 4D, 2.4L swap, 2.0 cams, SRT turbo, 52mm TB, gauges and 3.0 unmodded intake, BOOGERS! and Megasquirt! 250Hp to the ground.The srt engine will too work with a stock Neon trans. Just look under my hood. Also you can change the mounts. It's not that hard. The key does not have an actual chip in it but more of a resistor. If the PCM does not get the correct resistance value from the key then it will not allow the engine to run for much longer than ten seconds if that. Also just run megasquirt.
Well I have had my SRT powered Neon for about a year now and so far no issues. I have a missing 5th gear syncro but thats it (it was shot before I changed to the SRT motor).
