95 dodge caravan 3.0 not firing...need help
the water pump went out on this vehical. Before the van was running perfect other then the obvious water pump leaking. After the install of the new water pump everything was reassembled. Now the van wont fire, I checked all the spark plug wire and each are getting power, i replaced the spark plugs as it needed a tune up. I triple checked all wire plugs unhooked to make sure they where secure and in place. i can only assume the timing is off, but i dont have a large amount of experiance dealing with timing. help would be appreciated. or if anyone has other suggestions as to the issue they would be welcomed.
Warning: This post may be subject to possible misinterpretation!
Sarcasm Warning: Content may not be suitable for viewers without a sense of humor or irony!
http://www.myspace.com/fugheddaboudit
