1997 Neon turbo Questions
I have a 1997 dodge neon DOHC and im putting in a turbo kit. i have most of the parts i need just need to find out what size fuel pump, injectors to use and what type of computer programe to adjust a\f ratio.
use ss lines, and an fitting's on your fuel....dont go cheap here you also need a rrfpr or boom more boost the stock fuel system will not give enough fuel. one cheap connection with fuel can cause a fuel leak which will easily burn your car to the ground. stock srt injectors are ok, mustang 24lb are pretty cheap and reliable, i have venom 23lb which were expensive but never failed me.
