Dodge mechanic..?..
Old Oct 29, 2007 | 03:51 PM
FC_V8's Avatar
Default Dodge mechanic..?..
im asking because of my dads van.. his 94 Doge caravan, check engine light is on.. im wondering how to check what code its throwing and fix it because its running kinda rough... any help appreciated. thanks
Old Oct 30, 2007 | 04:45 AM
Dano Moparo's Avatar
Grandpa
Check engine light on a 14 year old Caravan could be just about anything. I think there was a deal about cycleling the ignition switch three times and count the flashes.
If I were to guess I would say it's the O2 sensor, but who knows on something of that age, could be a battery temp sensor. Any shop with a decent scan tool should be able to pin-point it better.
Old Oct 31, 2007 | 07:22 AM
Kingss's Avatar
you would turn the key to the on pistion three times.
off-on
off-on
off-on: keep it on on pistion look at check engine it will blink count how many times it blink.it will be like one,two then one, two, three,that will be code 13 but you need to wait until code 55 comes out that the last one.
if you want you can call me i'll help you out on it. pm me if you need the my number.
