2.4 engine swap
Old Sep 26, 2007 | 04:26 PM
jeanpiere's Avatar
Default 2.4 engine swap
hi i just got a 99 neon with a shoc and i have a 99 stratus with a 2.4l auto tranny what do i need to get this sawp done
Old Oct 2, 2007 | 04:04 PM
neondriver's Avatar
neons.org-engine swap-read stickeys. its all there, motor mounts, dohc pcm, pin swap computer, change pully, few other small things,.
Old Oct 2, 2007 | 04:49 PM
Ahhhh Nick!'s Avatar
Out Of Towner
Yep, just go with the MTX tranny while you're at it also.
Old Oct 6, 2007 | 01:12 PM
jeanpiere's Avatar
i went to that site but everyone is talking about using the 3 speed tranny from the neon and use the pcm from a dual overhead neon..... i got a full stratus with pcm trany and wiring that i will like to put in there
Old Oct 6, 2007 | 05:06 PM
Out Of Towner
Use the DOHC Neon ecu.
Old Oct 6, 2007 | 05:48 PM
flea69691's Avatar
im back
i will buy the motor off u and give u a dohc neon motor and help u drop it in
Old Oct 8, 2007 | 02:12 PM
jeanpiere's Avatar
yea but i want a 2.4 with an automatic 4 speed trany the only problem i got is on my drive axels and on the mount for the trany cause im gona use the pcm from the stratus and the wiring
