Help
Old Sep 21, 2007 | 05:05 PM
lazarosrt4's Avatar
Default Help
How To Make A Srt4 Stock Turbo Boost Higher ?
Old Sep 23, 2007 | 11:44 AM
KrazyRider83's Avatar
Fawkin Skittles
WGA would be your first mod. Not too expensive but best bang for the buck. & even then, you don't want to go past 18psi on the stock fuel system anyways. The stock WGA spring is weak, & opens up at 4/5 psi. I'm running the Stage 2 WGA, a lil' better, spike 18, able to hold 15 till redline. Eventually will go with FW WGA...have you joined the SRTforum.com?
04 Neon SRT - (rebuild time)
03 B5.5 Passat Wagon 1.8T
Originally Posted by efficientkiller
none of this really matters at the end of the day...if you really want to know, the true answer is found in research, why post a ignorant thread & call it a debate? this is exactly why TR gets the critizism it does...
Old Sep 23, 2007 | 02:09 PM
lazarosrt4's Avatar
no i havent i just got a srt4 like 3 weeks ago
Old Sep 24, 2007 | 06:22 PM
The Mayor's Avatar
Only does digs!!
i have a forge wga, for sale $50 if you want it, will alow you to go to 18/19 psi. lmk
Old Sep 24, 2007 | 06:30 PM
Fawkin Skittles
Jump on that forum, join, whatever...but there is A LOT of info on that forum. Try to use the search engine, or just read through the post/threads. & if you can't find, ask away. Someone always has an answer whether their bein a smart ass or not .
Where in the Tampa area you located at?
Old Sep 24, 2007 | 07:27 PM
The Mayor's Avatar
Only does digs!!
hey Juan, i think he should buy my forge wga, i can hook it up and tune it for him.$50 you cant beat it
Old Sep 25, 2007 | 03:27 AM
Fawkin Skittles
That'll work...it's a start. That one come with the stiffer springs to swap in there? Or am I thinkin of another WGA
Old Sep 25, 2007 | 04:13 AM
lazarosrt4's Avatar
In The Rown An Country Area
Old Sep 25, 2007 | 06:54 AM
Ahhhh Nick!'s Avatar
Out Of Towner
I say you should buy Frank's wastegate!
Old Sep 25, 2007 | 07:29 AM
lazarosrt4's Avatar
Let Me See Some Pics
