Couple questions on tubro postions on SRT-4?
Old Aug 7, 2007 | 06:05 AM
Sippi's Avatar
Mitsu SON!!!
Default Couple questions on tubro postions on SRT-4?
Ok I know that tha turbo is mounted in the rear of tha engine bay. And plz don't negative rep me but its been a while since I've seen under tha hood but I'm sure that means thats where tha exhaust/turbo manifold is?
My questions is I've seen it on a video where tha turbo was actually mounted up front like maybe a towards tha drivers side so it can be done but how hard is it?
I'm sure this would mean a lot of custom work and a good bit of money but I'm sure it would be worth it due to an easier postion to work on rite?
Old Aug 7, 2007 | 12:29 PM
FLNeonRT's Avatar
BOOSTEDNATION.ORG
Yes and no. You still need room to plumb the exhaust all the way to the turbo and then awat from it and if your using a lrage turbo, that takes up room also. I'd be removing as much as I could from the engine bay and moving everything else lower. You also have to plumb intercooler lines, oil feed and drain lines.
Mike a.k.a. "Neon Mike"
AIM: FLNeonRT Yahoo: Super60R/T
Old Aug 7, 2007 | 02:48 PM
Figs's Avatar
Your better off leaving it around the stock location. Even though depending on what you want to do its a pain to get to. The turbo, manifold, o2 housing and downpipe are in the rear of the engine.
Whenever replacing any part back there usually like a O2 Housing you might as well do everything all at once... ported manifold, 3" O2 Housing, 3" Downpipe, ported and clipped turbo or one of those re-worked stock turbo's like PTP's SST.
There's many other options... you could just go outside of stock bolt on parts and go with a bigger turbo and what not.
Old Aug 8, 2007 | 02:32 AM
Sippi's Avatar
Mitsu SON!!!
ok cool!
Old Aug 12, 2007 | 07:11 AM
ACR2NV's Avatar
a.k.a. NeonDan
or you could buy an AGP cast manifold and the turbo options suddenly get pretty long
"if you got turbo lag, you ain't drivin' it right!!!" -Carroll Shelby
Skittles.....tasty arent they?
Try the newest flavors yet?...Orange blast and white mint
I specialize in SRT4 tuning/troubleshooting/repairs.....
