help with a 99 wrangler
Old May 25, 2007 | 07:04 PM
omgwtfbbq!'s Avatar
I race sailboats
Jeeps can pull along quite a bit thanks to those lovely little in line 6s. The problem youre going to run in to is trying to stop. My father regularly pulls around a large camper with his 98 sahara edition, but he has had an issue once or twice with the brakes locking up. Dodge makes some pretty crappy stop hardware, so make sure everything is in good working order before towing anything.
But still, I wouldnt go much over that tow limit. Also, that lift might kill clearances for the back of the trailer which could cause significant damage, not to mention having that hitch higher makes towing more of a hassel.
Bitches don't know about the twin turbo
BLACK FENDER PART OUT
Old May 25, 2007 | 07:08 PM
.Seth.'s Avatar
TR Balla Donor Supreme
fuck it, throw a 350 in that bitch and dont worry about it lol
Old May 26, 2007 | 05:30 AM
Tony G.'s Avatar
lol well the hitch ball wouldnt be much higher then stock (thanks to the invention of some rich guy) im putting dana 60 in the front and back 6 inch suspension lift front skyjacker and some 35's or 36's i was just wondering if i could get my stang to the track with that. *(im hoping so) also i know about dodge brakes lol i also have the plans to upgrade the entire brake system
Old May 26, 2007 | 08:26 AM
Sneakin Deacon's Avatar
PSSHHH x2
it'd significantly reduce the ability for you to accelerate. your going from like a 28" tall tire, to a 36" tall tire. the truck is going to have a lot longer gears, meaning less mechanical advantage to push the truck along.
some jeeps can pull, but wranglers and stuff cant, not much anyways. cherokee's can tow pretty decent but it all depends.
the 4cyl wranglers can only tow 2000lbs, or 1000lbs if they are automatic, they just dont have the power. found this little tow rating chart from Jeep.
Cherokee/Wrangler 2.5 I-4 2,000 (a)
Cherokee/Grand Cherokee 4.0 I-6 5,000 (b,c,d)
Wrangler 4.0 I-6 2,000 (f)
Grand Cherokee 5.2 V-8 6,700 (b,c,d,e)
Grand Cherokee Limited (4WD) 5.9 V-8 5,000 (b)
NOTE: Trailer brakes required on all trailers weighing more than 1,000 pounds.
(a) Automatic Wrangler rated 1,000 pounds.
(b) Requires weight-distributing hitch with a maximum hitch weight of 750 pounds.
(c) Requires trailer-towing package.
(d) Requires automatic transmission.
(e) 4WD rated 200 pounds lower.
(f) Maximum hitch weight of 300 pounds.
El Pendejo Loco
2002 Suzuki Hayabusa
1507 "dry" block
Brocks megaphone
Spencercycle 10" swingarm
MPS auto shifter
Hays convertible clutch
Yea, that about sums it up...
Old May 26, 2007 | 01:06 PM
Tony G.'s Avatar
hmm ok well thank you looks like im gonna need to get a truck also lol thats later ill just keep having my dad tow my car to the track thanks you guys.
Old Jun 11, 2007 | 02:56 AM
funford's Avatar
I pulled a 21' 2700lb (without trailer) v8 inboard. With this.
ohh ya, class 2 hitch. no problems what so ever. 4wlow walked up boat ramp without using gas. jeeps can tow shit just fine.
