Turbo Selection Help
Old Apr 11, 2006 | 04:09 PM
ReddevilSRT's Avatar
Default Turbo Selection Help
I am thinking about getting either Mopar stage 3 or AGP 50 trim with Walbro fuel pump, 750 cc injectors, and Apexi AFC-II. I am currently running stage 2 with toys and have K&N cold air intake, 180 degree therm., CCA Large FMIC, AGP motor mounts, MSD ignition and wires, MPX heat shield, HP racing 3" exhaust without cat, exhaust depot upp pipe, AGP lower pipe, and mopar blow off valve. I am looking for a reliable kit with little tuning needed. I use the car as a daily driver and very rarely take it to the track. I just want to be able to have the power there in case I deside to use it. Any feedback given will be appreciated very much.
Old Apr 11, 2006 | 04:59 PM
dsm_90's Avatar
fast, faster, gone
S3 without thinking twice, reliable and no tuning required and for you already having S2 with toys, your S3 price should be cheaper..goodluck with whatever your choice
frequency
Old Apr 12, 2006 | 05:05 PM
Thanks for the info. I have been leaning towards the S3, just wanted to see what others thought and are using.
Old Apr 12, 2006 | 05:26 PM
riven's Avatar
enjoy the stage 3 cracking manifold
2003 Solar Yellow SRT-4
1994 RT/TT - The Tank.
Old Apr 14, 2006 | 07:01 PM
dsm_90's Avatar
fast, faster, gone
how many ppl. who has had the S3 mani. with the proper install(support bracket)has had them cracked?-maybe a handful(I know of none). Any mani. can crack, I can't tell you the amount of DSMs(cause I'm an old DSMer)tubular mani. from good vendors have cracked in many places, you just have to pray and hope everything works right. One rule of thumb in this how much power can I produce world is IF YOU'RE NOT BREAKING STUFF, YOU'RE NOT GOING FAST ENOUGH-JOHN SHEPPARD(buy my transmissions-they are hard to break)----lol
frequency
Old Apr 15, 2006 | 02:37 AM
cali's Avatar
Skittle on crack!
Dont listen to Riven...manifold crack because
1. They dont install the brace(s)!!! Two brackets! one fo the 02 and one for the manifold.
2. Running higher boost.
I lean to stage3. Heres the trick...NO tuning required. With your mods & the toys kit, I can see 400 in your future.
Also if you are strapped for cash, you can buy the non-toys kit and get the toys simulator ( doesnt look as nice), to convert your non-toys to toys, for cheap.
I beat the snot out of my s3 and not a single issue. I can get 12MPG or I can get 32MPG.
You can quit watching me now....
Old Apr 15, 2006 | 06:48 PM
Default 50 trim
Thanks for the info. I was leaning towards stage 3 but Icame across a deal I could not refuse. I just got a 50 trim with ceramic coating, manifold, tail 44mm wastgate, SAFC-II, walbro 255, and tach driver off of srtforums for a good deal!!! So hopefully I will have the kit by the end of the week and will have it in by the end of the month.
Old Apr 16, 2006 | 04:08 AM
slow poke's Avatar
stg3 if you want turnkey performance.... but if you like to tinker and tune things then maybe a 50 trim... personally, i'm lazy, so it was stg3 for me !!!!!
oh yea, don't listen to riven !!!!!!
just visiting this screwwey planet.
woohoo, 9.84 @ 137.7 mph on a 9" slick !!!!
Originally Posted by Gooser
just cause you have a cowl hood on your Honda doesn't mean you can hang out here.
Old Apr 16, 2006 | 04:28 AM
riven's Avatar
yeah...anything that comes out of my mouth is total bs
Old Apr 16, 2006 | 05:37 AM
cali's Avatar
Skittle on crack!
Well...does your car run
