Anyone used anything from Absolut Boost?
Old Feb 27, 2006 | 06:02 PM
Nolimitslja's Avatar
Default Anyone used anything from Absolut Boost?
http://www.absolutboost.com/index.php
I saw they had a CCA direct fit FMIC thats considerably larger than the stock and suppose to be tested and everything but it's only 350.00 and most of the ones I've found this size are at least 500.00 or more. Anyone know anything about this company or their products?
http://www.absolutboost.com/catalog/...products_id=26
This is the actual link to the FMIC I was referring to.
Old Feb 28, 2006 | 02:54 AM
Josiah's Avatar
Peon on steroids!
the reason that one is only $350 is because its a tube and fine design, not a bar and plate design like the more expensive ones, its debateable whether tube and fin or bar and plate give you better cooling, but people act like bar and plate always does a better job....maximum boost says that bar and plate offers less pressure drop, but does not cool as effectively as the tube and fin design, I personally think they are about even...the gains you get from reduced pressure drop is offset from the somewhat warmer air temperature
