timing sproket
hey when it was removed a little rectangle piece of metal came out. what is this piece...ill post pics
that is the crankshaft sprocket key, if you turn the end of the crankshaft you will notice a little groove in it, you will need to tap the key back into the crank with a hammer, you'll notice the key groove on the sprocket for correct timing alignment, your sprocket looks broken, I'd reccomend a new one from the dealer, they are $12
p.s. dont reinstall the sprocket until after you put the oil pump back on
yeah i have a new oil pump and i ordered the new sprocket fri. ill look for the groove
