injectors
on
injectors
are the injectors for a 98 dohc 2.0 neon hi or low imp.?
on
cool. what poundage are the srt's and can i use those in place of my first gen stock?
SRT injectors are 52lb/hr and will not run at all on the stock computer, it wikll always be too rich, even if you have a FPR and turn the base pressure down to 15psi it will still be too rich...I use SRT injectors, but I dont run off the stock computer either...I could idle 100lbers if I wanted to
on
on
ok any others that i can use from other cars? if not ill just buy new ones what poundage should i get with my set up? my set up is listed in the "whats your setup"
I would say high impedance 24lb/hr injectors would work well with your setup...in conjunction with a SAFC or FPR to adjust fuel, not many cars came stock with 24lb/hr injectors though, only the NA mustang cobras come to mind(at least i think they were 24lb/hr units) but many places sell them in the aftermarket...or you might be able to find a set on ebay for fairly cheap
