couple questions
Old Jan 28, 2006 | 06:14 PM
kapenna's Avatar
Default couple questions
ive finally got the block out 4 months after the head. anyways
i have the crank off but it still hasx the oil pump on one end because i cant get the timing sproket off. how do i do this. and im getting the crank balanced.....is there a certain rpms i should have it balanced at. im planning on haveing the bearings cryo treated along with the crank. anything else i shold do to this block? i need as much info as posible i only want to build this block once.
but i got great news............................i just saved a ton of gas money by switching to a honda!
Old Jan 28, 2006 | 09:37 PM
Josiah's Avatar
Peon on steroids!
use a 3 bolt type puller for the crank sprocket, you will need to get different bolts than the ones at autozone come with though...I think they are m8 bolt holes(could be mistaken though, anyway there are 3 hole in the face of the sprcket, test fit severl bolts till you find one that fits...take that to ace ahrdware and find 3 that are that thread and decently long, then put them on the puller with whatever washers are needed and pull the sprocket...you may need to remove the whatchamacallit though(little piece of keyed metal stuck in the crank behind the sprocket to line up the sprocket), can be removed with some pliers and installed again with a hammer by tapping it into place(on second thought you probably wont need to remove it after all ...as for the RPM, when I got mine balanced in the sebring motor I just took it to a machine shop and told them to balance it for me w/ none specified, dont know, they will demand the flywheel and whatever crank pulley you are using at the same time thoguh(even though they arent needed, I gave them to the shop anyway)
heres a current thread on it on neons.org
http://forums.neons.org/viewtopic.php?t=244538
Old Jan 29, 2006 | 04:18 PM
kapenna's Avatar
ok thanks i have a puller. craftsman. ill see if that works. if it doesnt and i have to try the chisle thing where can i get a new one other than dodge.
Old Jan 29, 2006 | 04:40 PM
Josiah's Avatar
Peon on steroids!
only dodge, but its only like $12, no big deal
Old Jan 29, 2006 | 04:48 PM
HPNOTIQracing's Avatar
ok
Uploaded with ImageShack.us
