Engine swap
Old Jan 27, 2006 | 06:58 PM
cuwa's Avatar
Default Engine swap
I have a 1995 dodge neon sohc and i wanted to know what other engines would fit. it doesnt matter if its dodge or mitsubishi. ne help would be great.
Old Jan 27, 2006 | 07:33 PM
mpbiv's Avatar
Rod Bearing Eater
2.0L DOHC, 2.4L DOHC, 2.4L DOHC Turbo
If you are determined, 2.2/2.5L SOHC Turbo will also fit. I have seen it done, although there is probably only one person who has done it.
Patrick
05 SRT-4: Daily Driver, 11.9@117.4
88 Aries: 2.2L Turbo (Powered by Megasquirt II)
Old Jan 28, 2006 | 04:14 AM
Josiah's Avatar
Peon on steroids!
any engine will fit if you have the time money and welding skills, but yeah, those are the only ones that are even close to relatively easy(although I believe someone swapped an early turbo dodge motor in as well, over on neons.org)
heh, just noticed you just said that
Old Jan 28, 2006 | 11:38 AM
SlowAssNeon's Avatar
Typical Peon Owner
seen two neons with the VNT motor in em as well, and both owners swear they will never do it again since it was so much work lol.
have seen pics of someone fitting a 4g63t in the neon, but without tranny, hoses, wiring.. this was quite a while ago now, and havent heard anything about it since so i dont know if he abandoned the project or what. havent exactly seen him online so ill have to try to get a hold of him somehow to see what happened there.
your best bet is to stick with the neon 2.0 sohc or dohc, or the 2.4 swap or srt4 swap.
Flying burritos? Brilliant!
Old Jan 28, 2006 | 12:03 PM
Josiah's Avatar
Peon on steroids!
ack, do NOT suggest an SRT4 swap, its a huge PITA, even if you use the srt stuff to do it, best bet is a pre 03 2.4 using SRT internals if you go that route
Old Jan 28, 2006 | 12:41 PM
Typical Peon Owner
while yes, the 97-02 2.4 with srt4 internals is an easier route to go.. i still will mention a full srt4 swap. sure theres a lot more work involved on getting it into a 1g.. but its still doable
Old Jan 28, 2006 | 12:51 PM
Josiah's Avatar
Peon on steroids!
:::grumbles::: doable if you dont mind your car being down for 8 months that is...he he, actually most of that time was me tracing down problems with the stock wiring...one after another...heh, do you know that the computer has to supply voltage to the fan motor for the heater? how stupid can you get...I ask you, what reason does the computer have to control the heater? its not like we have climate control
Old Jan 28, 2006 | 02:16 PM
Typical Peon Owner
another way to help keep temps down if it gets serious enough. thats about all i can think of at least lol.
yeah, 8 months would be quite irritating. sucks youve had so many problems. ive talked to others thatve done the swap and have had it done in a weekend.
Old Jan 28, 2006 | 02:23 PM
Josiah's Avatar
Peon on steroids!
heh, I run it all off MegaSquirt, so it took me awhile to trace down all the circuits controlled by the stock paperweight and bypass them...its still not going to run again until monday(waiting for MS to get back from a retrofit) I admit my way is far more difficult than SRT plug and play harnesses, but I'm tired of trying to fool stock computers to get them to do what I want, hence, full control the hard way
Old Jan 28, 2006 | 09:11 PM
"?"'s Avatar
The 4 banger race only block that mopar makes will also fit. If I had the time I would drop that in my 96.
