cam timing
Old Jan 24, 2006 | 02:44 PM
kapenna's Avatar
Default cam timing
hey when i deck my head does it automatically change cam timing. if so what do i do to correct it? if i line everything in time after the deck it will be in time right. or does it acctually change because tdc distance is diff?
but i got great news............................i just saved a ton of gas money by switching to a honda!
Old Jan 24, 2006 | 02:53 PM
Josiah's Avatar
Peon on steroids!
no, cam timing remains the same, if you are worried about the timing being dead on, you can always index your cams
Old Jan 24, 2006 | 03:27 PM
kapenna's Avatar
it remains the same because i didnt touch the cam angle sensor right. oh and does it change spark timing.
the reason im asking is because this idiot is trying to tell me this because suposedly his saturn which has a chain does this...he says.
Old Jan 24, 2006 | 05:20 PM
Josiah's Avatar
Peon on steroids!
well if you take a half inch off the head, then yeah, it would, but "decking" is hundreds or thousandths of an inch, not enough to make any real difference, just enough to true the surface, it would take quite a bit of material missing to change the cam timing, and at that point you would get valvetrain interference before cam timing changes, this is true of any overhead cam engine...I can see that with a chain it might cause tensioner problems(though the tensioner would still take up the slack if you ask me)
Old Jan 24, 2006 | 06:24 PM
Green Monstah's Avatar
bastid
decking or shaving does actually change cam timing in Saturn engines. It retards it slightly.
Old Jan 25, 2006 | 02:27 AM
Josiah's Avatar
Peon on steroids!
hmm, hundredths of an inch retards cam timing? well, it is interesting to know anyway, but even so I cant imagine that its going to retard it more than 1/4 of one degree if decked to the max...are we talking the SOHC or DOHC Saturn engine btw?
Old Jan 25, 2006 | 04:45 AM
kapenna's Avatar
my comment was about a dohc
