need info on stock rods
Old Oct 4, 2005 | 01:19 PM
hiwayhuntr's Avatar
big turbo=little traction
yeah,just roll into it and feel the power out.as long as u know how to drive u should never snap axles
For all your local neon/srt Tunning and Fab
contact me for unbeatable prices and quality
Old Oct 6, 2005 | 12:45 PM
kapenna's Avatar
thanks ive got about 2600 into this engine so far the body looks like hell and the interior is full so im am stock weight still. havent finished this build yet, still finding out things before i put it together. im doing this car the right way.ive considered the axles already so untill i can afford them im going with shit ass tires so that if i get under to much load they will just break loose.
anyways any ideas on times or hp for this setup?
Old Oct 6, 2005 | 03:55 PM
Josiah's Avatar
Peon on steroids!
w/ no bottle? you might be pushing 200 or so...hard to tell really, I wouldnt count on any more than that anyway...if I were you though I would have gone with a 2.4L block...better base..either turbo or NA...with 18s a 2.4 would be a beast...but the #1 reason for 2.4 is torque....30ft lbs more than a 2.0 stock for stock, no reason not to unless you have already bought internals...if you have...trade them for 2.4 pistons and build a 2.4 instead, I guarantee you would be more happy with the results, with 200HP you should be able to pull off a low 14 I think...maybe a 13.9 if you are very lucky
Old Oct 6, 2005 | 04:04 PM
kapenna's Avatar
yeah i had thought about the 2.4 swap but didnt feel that for just 30lbs of tq was worth the effort, and also in the end what would be the difference in the finished product between the 2.0 and 2.4 using the same parts? i already got the internals je pistions, eagle rods, main and rod bearings, rings, oilpump. so i already spent the money for the 2.0
