Omni GLH-S?
No Ants Drift Member
on
Omni GLH-S?
im picking up an Omni GLH-S and i need to replace the headgasket... any things i should look for? anyone have a service manual so i dont fuck this up? any help is appreciated
RIP Tim. i miss you, buddy
where did you find one of these? What number is it?
its a 2.2L SOHC so just got to www.forwardmotioninc.com for all your needs, they carry alot of parts that DCX dopesnt sell anymore.
"if you got turbo lag, you ain't drivin' it right!!!" -Carroll Shelby
Skittles.....tasty arent they?
Try the newest flavors yet?...Orange blast and white mint
I specialize in SRT4 tuning/troubleshooting/repairs.....
If it is just a head gasket you need, I would skip Forward Motion. I'd suggest trying FWD Performance (www.fwdperformance.com) or Turbos Unleashed (www.turbosunleashed.com). I'd also suggest using a Mopar Performance head gasket (MP2005) and Mopar Performance head bolts. The head bolts are torque to yield and should be replaced.
The easiest way to swap a head gasket on these cars is to remove the head with manifolds and turbo as an assembly. Torque sequence for the head bolts is 45-65-65 ft-lbs and then a 1/4 turn working your way from the center bolts towards the outside bolts in a circular pattern. Just to further clarify, make sure you torque all the bolts to 45 ft-lbs before you step up to the next torque sequence of 65 ft-lbs; similarly make sure all the bolts are torqued 65 ft-lbs before your start turning them a 1/4 turn.
If you use new bolts and follow the torque sequence properly, the new headgasket should last a long time, baring extreme cases of course.
Good luck
Good luck
Patrick
05 SRT-4: Daily Driver, 11.9@117.4
88 Aries: 2.2L Turbo (Powered by Megasquirt II)
Patrick
on
ok, so i have it and it turns out it is an 86 omni glh turbo.. not 's'... sigh.. but it does have a full roll cage, racing bucket, sheet metal dash with all autometer gauges and 5 stock wheels. whats this thing worth in decent shape? i have some cleaning up to do on it and need to fix the headgasket (i might just sell it as is, just cleaned up)
dang, i was gonna say a GLH-S... "goes like Hell...Sorta"? lol those things sure are cute. wasnt there DOHC head from the minivan that you could use on those motors?
Some people have successfully built hybrid 2.2/2.5L DOHC engines by bolting a neon 2.0/2.4L head to the 2.2/2.5L block.
Patrick
Patrick
Most of the lotus desinged head went to mexico oddly enough.
There are points in life where one looks at his or her situation and says "how the fook did i get here?" ... this is one of those instances....
hey taylor, i'll take the car from you. I know which car it is, i tried without luck to reach the owner hence why it got sold off by the shop it was at. Hit me up on a PM..
