Stock injectors?
Old Apr 13, 2005 | 02:50 PM
Skittle's Avatar
You Can't Moderate Me.
Default Stock injectors?
I have a 04(550cc)...but how much hp can the stock injectors go up to?..Nitrous is gonna be applied to my car in the next two weeks,i was thinking about 17lbs+50 shot...but id think my car would be dead lean...unless you guys can convince me otherwise ...which would be safest boost levels with a 50/60 shot?
R.I.P Pablo "Fathead" Garcia & Kevin "Slo_Si" Gonzalez Forever in our hearts.
Old Apr 13, 2005 | 03:28 PM
Josiah's Avatar
Peon on steroids!
the stock injectors I heard are between 42-48lbers...which should be good up until about 360, maybe 370hp or so
Old Apr 14, 2005 | 04:40 PM
riven's Avatar
bahaha. thats funny right there, I dont care who you are.
2003 Solar Yellow SRT-4
1994 RT/TT - The Tank.
Old Apr 14, 2005 | 05:50 PM
Josiah's Avatar
Peon on steroids!
hah hah, so funny, wait, I forgot, you cant adjust fuel pressure can you?, besides, 04s have bigger injectors than 03s
estimated hp x .5 / # of injectors
this is a rough formula but it will work for our pourposes
360x.5=180 180/4=45 and guess what size stock 04 injectors are? so funny isnt it? hell, people have run over 400HP on 48lb injectors, granted, they are using more....extreme...fuel pressures...but still
Old Apr 14, 2005 | 05:57 PM
riven's Avatar
the funny thing is you said they support 350hp. *coughbullshitcough*
Old Apr 14, 2005 | 06:01 PM
Josiah's Avatar
Peon on steroids!
ok, let me revise that, on a stock SRT4 setup they probably wouldnt, but thats because SRT4s use a wimpy 43psi or so for fuel pressure too
Old Apr 14, 2005 | 06:07 PM
riven's Avatar
no, they use 58psi.
Old Apr 14, 2005 | 06:25 PM
BrYaN H's Avatar
5 bucks youll win
lol this is great you guys are awesome. ok who would win in a fist fight o4 injectors or 05 injectors?
Old Apr 15, 2005 | 05:41 AM
Josiah's Avatar
Peon on steroids!
04 and 05s are the same as far as I know, my point however is that these injectors will support the desired power level....probably not easily but it can be done....lets put it this way, my 36lb injectors flow closer to 40lbs at 50psi, with about 75-80psi I think those injectors would do fine for the required power level, probably even without...depending on what PSI these injectors are rated at, 45lbs at the usual 43psi rating, or 45 at the 58psi rating
