MegaSquirt DIscussion
Old Mar 15, 2005 | 11:49 AM
djkomplex's Avatar
TR Balla Supreme
get a apexi avc-r, it will help your traction problems
TRs Nastiest Sounding SRT-4 Crew: #001
Gameboy Tuning Crew: #001
aim: turntablism0101
www: http://www.myspace.com/djkomplex
party like a rockstar, play like an all-star and fuck like a pornstar.
Old Mar 15, 2005 | 01:22 PM
Josiah's Avatar
Peon on steroids!
naw, get a Megasquirt for the same price, use it to control boost....and fuel...and spark...and whatever else you want to control...he he
Old Mar 16, 2005 | 05:20 AM
FLNeonRT's Avatar
BOOSTEDNATION.ORG
Um, I may be wrong, but I don't think that Mega Squirt will do what it does for the 1st Gen. on an SRT/ They might have come out with something so I may be wrong. Last I heard, there wasn't anything like that available for the SRT.
Mike a.k.a. "Neon Mike"
AIM: FLNeonRT Yahoo: Super60R/T
Old Mar 16, 2005 | 07:00 AM
Josiah's Avatar
Peon on steroids!
nope, MS is universal...you would have to mount a ford EDIS wheel and sensor if you wanted spark control, but if your fine with just fuel control data logging and boost control, it will work fine with an SRT4, I'm sure someone will write some code to decode the 02-up crank trigger setup soon anyway so soon enough it will be just as functional for a later 2.4 as it is for the rest of the 420a crank trigger type family
Old Mar 16, 2005 | 02:53 PM
FLNeonRT's Avatar
BOOSTEDNATION.ORG
Yeah, I knew it was universal. Anyways, good deal then. Good to know. Thanks.
Old Mar 16, 2005 | 06:14 PM
Josiah's Avatar
Peon on steroids!
one note on that....the MS boost controller is still in the works, some code tweaking would probably be needed to get to work to its full potential...easy enough to do
Old Mar 17, 2005 | 03:36 AM
Back-n-Black's Avatar
SRT-4 Budget Racer.
Originally Posted by Skittle
Yessir...mines a 04'
Skittle you running a map clamp? Just wondering cause your boosting so high. Thanks. You can pm me if you don't wanna post.
Randy
Old Mar 17, 2005 | 05:33 AM
Josiah's Avatar
Peon on steroids!
I know I am....until next weekend anyway....map clamps suck though, mine has broken like 5 times and only really works when it feels like it, its either stage 2 or ...no its stage 3 that comes with a 3 bar map sensor though
Old Mar 17, 2005 | 12:18 PM
FLNeonRT's Avatar
BOOSTEDNATION.ORG
Can't you pick up a GM 3-bar for somewhat cheap? Would that work?
Old Mar 17, 2005 | 12:20 PM
imagirl!leghumpme's Avatar
silly tr....
if you get the pigtail from gm is 42 dollars, the 3 bar module itself is like 20....
darn static ip's.....
Off-Topic Likes Getting His Salad Tossed... by ugly fat slores
