Blowoff valve
Old Jan 18, 2005 | 06:42 AM
Josiah's Avatar
Peon on steroids!
well, the 2.4 has the same crank trigger setup as the 420a(which by the way is only in the NA eclipse and avenger, the DOHC neon has the same block, but the head is reversed and somewhat bettter flowing) the 2.4 is a different block....but yes, you could swap a 2.4 into your NA eclipse if you used the eclipse head, you would probably have to figure out something for the passengers side motor mount though, but all your other mounts should bolt up(could be wrong about this, have only done the swap in a neon, but I read about someone doing it in a NA eclipse), you would need to use a 2.4 from a pre 2001 stratus/cirrus/sebring/caravan for your eclipse head to bolt on and you would also need to reverse your coil leads, but other than that its a direct swap(for the neon)
p.s. sorry for getting off topic guys
Old Jan 22, 2005 | 01:11 PM
fresh&clean's Avatar
I love Lamp
My friend mike he has a silver 05 srt4 with a mopar bov sounds good I like it better then the greddy ones they sound like canaries.
Old Jan 22, 2005 | 08:07 PM
neondriver's Avatar
Neondriver-are you using a stock Srt-4 turbo?..
Yes, out of an 04
