Srt 4 manifold on 1st gen
I have heard that it can be done but I am wondering if it is a direct bolt on or if some of the manifolds holes are a little off and what would need to be done to fix/solve the problem. Also with a boost controller is it possible to turn down the boost from the stock 15 pounds? Thanks for any help.
The radiator and the fans are all up in the front and the manifold sits in the back, so i really dont think that would make a difference. Or do you mean if I put on an intercooler that the pipes that come up to the front of the car will hit the radiatior and the fans
thanks for the help though
yeah that was the rumor i was hearing so asked a few people to verify and i got the same answer hear as everywhere else. Hopefully it actually works because i just bought one with the turbo for 250!!
Thanks for all the help!!
it will work, thats what im putting on my car, the only mod is the ports are bigger on the manifold so you need to port it a little to keep the air flowing smoothly. ive seen it done on neons before. but there is alot more than just the manifold and turbo to get it to work my turbo has been sitting around for 2 months ans i still need more parts, its tough to figure all the little things out especally if your a beginer like i am. but on a dohc with stock internals 190 hp @ 5.5 psi is about what you will get.
Originally posted by GsEclipse02
so the srt manifold will bolt on to the 420 A engin is what your saying?
SOME PEOPLE ARE ALIVE SIMPLY BECAUSE IT IS ILLEGAL TO KILL THEM
