2.4 liter head on a 2.0
Old May 25, 2004 | 12:28 PM
Sweet R/T Man's Avatar
Default 2.4 liter head on a 2.0
I know the question has probalby been asked a thousand times but is it posible to put the 2.4 liter head onto a 2.0. If so do you just build it with the parts for the 2.4 and replace the old head? Any help would be appreciated.
Old May 30, 2004 | 11:24 AM
LILKEEZY2003's Avatar
04 SRT4
Default heads
its not worth the effort to put a 2.4 head on a 2.0 block if anything u should put a 2.0 head on a 2.4 if ur plannin on swappin do it that way its much easier but when u take the 2.4 head off make sure u take the rockers and lifters out of it cuz u will need them in the 2.0 head if u plan on runnin bigger cams then 12's if u need any otha info hit the forum bakk up lata edwin
95 4DR NEON-350
NEW MOTOR ....-000
MOTOR MOUNT INSERTS-50.00
NITROUS KIT-250
SLICKS-200
THE LOOK ON A HONDA ONWERS FACE WHEN HE GETS HIS AZZ WHOOPED BY A NEON-PRICELESS
Old May 30, 2004 | 11:47 AM
figment's Avatar
Jonathon
2.0 and 2.4 heads are the same. unless it is a pt or srt head.
i also think that 2000 and newer heads are diffrent also but other wise they are the same
SOME PEOPLE ARE ALIVE SIMPLY BECAUSE IT IS ILLEGAL TO KILL THEM
