97 neon help
i have a 97 dodge neoni was driving then the car shut down i have oil on the sparks plugs and on the map sensor and i replace the coil and the map sensor i did a compress test i have 180 all across it still wont start
Another thing, are you sure that you are not getting spark?
Dont mean to be a prick, but I have to ask, how did you check for spark?
How's your fuel pressure?
You can quit watching me now....
Originally posted by flybyuin2.2
most likely a cam sensor or the crank sensor is bad
Make sure you dont have broken wires.
