Time to spill yer brains
Old Jan 27, 2004 | 04:19 PM
cali's Avatar
Skittle on crack!
Default Time to spill yer brains
Ok, so if I park the car overnight in the garage, when I wake in the morning, I can smell fuel vapors.
long story short, I installed a Return line. The return is tapped on the plastic cover of the tank ( next to the stock filter/regulator)
There are 2 o-rings on the bulkhead where the tap is. I replaced the tanks' rubber seal also.
I still smell it :o :o Doesnt leak any fuel form 50-70PSI at all. Tossing the car violent around with half tank yields no leak.
Any thoughts?
You can quit watching me now....
Old Jan 27, 2004 | 05:07 PM
flybyuin2.2's Avatar
was it after installing the return line you noticed fuel vapors? if you had the gas tank down maybe the vent line/tube got disconnected, is the smell under hood or inside the car?
Old Jan 28, 2004 | 07:53 AM
cali's Avatar
Skittle on crack!
it was indeed after. I checked all the evap lines, even zip tied the ones that werent clamped. The smell is in the tank area, under the car.
