Chassis & Suspension Tech Cages, braces, suspension set up and more
Most Revolutionary Engine In The World? 160 HP. 25K RPM Redline. Only 35lbs - AAH 583
Old Jul 18, 2022 | 01:23 AM
Default Most Revolutionary Engine In The World? 160 HP. 25K RPM Redline. Only 35lbs - AAH 583
Who Wants The Most Revolutionary Engine In The World? 160 HP. 25K RPM Redline. Only 35lbs - AAH 583
Streamed live on Dec 16, 2021
4.5KDislikeShare
Save
Autoline Network
91.5K subscribers
Old Jul 18, 2022 | 01:25 AM
Default Unfortunately runs on hydrogen.....why can't they make it run on gas for the average
Unfortunately runs on hydrogen.....why can't they make it run on gas for the average person?
Old Jul 18, 2022 | 01:27 AM
Default The Difference Between Gasoline And Hydrogen Engines 1,469,894 views
Dec 19, 2018
36KDislikeShareSave
Engineering Explained
3.23M subscribersHow hydrogen combustion engines work, versus gasoline engines. Hydrogen combustion engines can be more efficient and with better emissions versus gas engines, due to the fuel differences of H2.
This video will look at eight major differences between gasoline and hydrogen fuels used in internal combustion engines. This includes the combustion reaction and byproducts, air fuel ratio, ignition energy, flame velocity, auto-ignition temperature, diffusivity, quenching distance, and density.
These properties result in drastic differences between using the two fuels, though both can easily be adopted and used in traditional otto-cycle piston cylinder engines, often with little modification to the existing engine hardware. Are hydrogen engines the future of internal combustion? Let's find out!
Old Jul 18, 2022 | 01:29 AM
Default Toyota's New 455HP Hydrogen V8: Everything You Need to Know 209,355 views Mar 2, 2022
Mar 2, 2022
4.9KDislikeShareSave
Dust Runners Automotive Journal
73K subscribersThey made changes to the injectors, heads, and intake manifold. The strangest change to me is that they reversed the flow of the heads. In terms of performance, they're claiming 455HP at 6,800rpm and 398lb-ft of torque at 3,600rpm, so it's a tiny bit down compared to the 2UR it's based on, but that's still a crazy amount of power naturally aspirated, especially considering it outputs zero emissions.
Dec 27, 2019 11:14 PM
Jeremy2792
Sep 29, 2005 08:38 PM
Toma
Feb 8, 2005 08:53 AM
