Chassis & Suspension Tech Cages, braces, suspension set up and more
How To DIY Prepping a Demolition Derby car
Old Jan 25, 2019 | 02:00 PM
Default How To DIY Prepping a Demolition Derby car
Crown Vic Demolition Derby Car Chassis Prep.
253 20 Share
Save
Published on Jul 22, 2017
Shaw shares some tips on how to build a limited build class car.
Old Jan 25, 2019 | 02:02 PM
project burn barrel 2007 crown vic p71 how to tilt a derby car
25 2 Share
Save
Published on Jan 10, 2017
time to tilt the crown vic my friends only end up doing a 3/4 tilt very small probably will not even do any thing but at least i know how to do them now for future derby usages
Old Jan 25, 2019 | 05:47 PM
A Way To Wedge Your Derby Car
103 8 Share
Save
Published on Oct 17, 2012
This is a video about how I went about doing my the trunk area of my car derby and how I did it. Thanks for watching!
Old Jan 25, 2019 | 05:48 PM
crown vic axle upgrade for demolition derby project "burn barrel "
62 2 Share
Save
Published on May 17, 2017
the factory 8.8 is not going t be enough for this car, i see too many car being taken out because of the weak rear axles . so i plan on p grading the axle ford axle in a ford car ford 9 inch install into a 2007 rown vic
Old Jan 25, 2019 | 05:50 PM
crown vic axle shaft fix1980-2011 derby car
25 1 Share
Save
Published on May 25, 2017
picked up this from a friend and he asked if i cold fo the axle shaft for him i said sure
Old Jan 25, 2019 | 05:54 PM
Demolition tricks and tips. Spotting cheated frames. And the methods used.
116 15 Share
Save
Published on Jul 8, 2011
Just a quick video on spotting cheated frames and how and why they try these things
Old Jan 25, 2019 | 05:59 PM
Demolition derby tips. Spotting welded frame seams.
24 0 Share
Save
Published on Oct 12, 2011
Short video of the difference between factory welds and re-welded seams.
Old Jan 25, 2019 | 06:01 PM
I never see Caddys do well since I was little most of the Caddys I have seen don't have the power and they seem to go straight to the ground Impala New Yorkers and lincolns are my favorites I mean new ports do good too but there's mostly 90s cars now it kind of sucks I miss the old cars but any car can be strong and do good you gotta pre bend notch it and weld it in the right place I personally can't weld worth shit my cousin is great at it though he has a degree or some shit to do it
@EzyRyder707
We are allowed full seam welding. But I was asked to do this video. Because some officials could not spot welded frames at another small derby. If you have never seen a derby car I guess maybe that could be hard. I don't know I weld for a living and know how to tell.
Old Jan 27, 2019 | 02:22 PM
Default Prebending the frame on my demo car
7 2 Share
Save
Published on Mar 13, 2012
My "how to" video on how I pre-bent the frame on my demo derby car. We will just have to wait and see if this work does any good.
