Chassis & Suspension Tech Cages, braces, suspension set up and more
DIY Four Wheel Alignment
Old Oct 7, 2007 | 09:55 AM
thetech's Avatar
Default DIY Four Wheel Alignment
Was curious to know if any here do their own wheel alignments?
What techniques do you employ?
Is caster/kpi, thrust angle, bump steer.......... etc, ------ calculations part of your solution?
Thats a New Concept
Old Oct 7, 2007 | 11:44 AM
Mars_302's Avatar
Race Photographer
toe can be done with a tape measure. You can buy a level tool for doing camber
Old Oct 7, 2007 | 03:17 PM
jlude90's Avatar
aspiring luder
Eastwood Co. - Fasttrax Camber/Caster Gauge
i'm thinking about picking up one of these
Old Oct 8, 2007 | 07:22 PM
Outkasted24's Avatar
** I ♥ Old Skool **
Woah, Me Likey Nice Find!!!
My Flickr
slam.poke.drop.tuck.dope
Old Oct 9, 2007 | 05:55 AM
thetech's Avatar
Default Do you desire more?
Alot of the current alignment gear is dated........... It's been used for so long that the "art", has become stagnant.
Are the use of bubble's and fractional measurements adequate for your needs.
Simple Example/Question (their are many):
When measuring caster; do you need turnplates/slip-plates?
The answer of many -- is yes, but this requires a 20 degree turn sweep -- and many chassis' wedge as a result of the sweep. This is the primary reason for the plates -- to eliminate any bind.
Some chassis' will not turn to that degree -- and as most bubble gauges are calibrated to the 20 degree sweep, an error will result in the caster calculation. Would any here desire to only turn the wheels let's say 2 degrees to get a resultant?
Is this even a concern to those of you doing alignments, (I will note that asymetric casters will unbalance a chassis)?
I have noticed that some of the top D1 cars run very little caster, very little SAI/KPI, with a small amounts of neg. static camber. The steering must be very light (but sensitive), concerning feedback to the driver, making set-ups procedure that much more delicate.
www.thatanewconcept.com
Old Oct 9, 2007 | 02:43 PM
jlude90's Avatar
aspiring luder
i'm not sure what you're getting at, do you have an alternative?
and i can't get anything on that link
Old Oct 10, 2007 | 05:11 AM
thetech's Avatar
Default link
Sorry I missed a key-stroke............................ probably should copy/paste rather than do it manually!
Yes, I have an alternative at:
Thats a New Concept
Old Oct 26, 2007 | 07:51 PM
88RedRex's Avatar
Protected Taurus .45/.410
i use string with knots tied in it
New sig. coming soon
Code 52 VTAK On A Switch
MCOR Automotive LLC
http://www.mcorautomotive.com/
PM MCOR for any electronics, upholstrey, accessories or window tint (813) 362-5454
They will take care of you as they did me
Old Oct 27, 2007 | 12:22 AM
I do alignments for myself as well as for customers.
I use the alignment setup like they use on Race cars at Indy.
Bump steer is a concept that the critics would benefit from
by purchasing your software.-Bob
Thats a New Concept
Old Oct 27, 2007 | 12:26 AM
Kernon's Avatar
RIP PABLO THE MAN GARCIA
sport compact i believe did that awhile back
