Chassis & Suspension Tech Cages, braces, suspension set up and more
benders
Old Mar 6, 2007 | 05:40 PM
blackwagon's Avatar
"color blind kid"
Default benders
Anyone have any first hand experience with any manual benders? Any brands recommended or brands to stay away from? I don't feel like dropping the extra coin for a hydraulic bender and could use the work out anyways.
Learn how to use the feedback system! When people don't fallow through with a deal, fucking make it known! of course everyone has all positive points, no one fucking gives negatives for flakers, if you start giving negative feedbacks for flaking maybe people on tr will stop making stupid ass posts about wanting to buy shit then not showing up for the shit.
Old Mar 6, 2007 | 05:54 PM
baconpancakes's Avatar
I hurt my nose.
my buddys all love manual over hydraulic. idk why, i havnt got to use either just yet.
www.SAVAGEGFX.com
Old Mar 6, 2007 | 11:05 PM
BLUE2KSS's Avatar
Mechanical Engineer
ive gotten used to the manual, because the one i use bends 4 degrees per notch. im just used to it, and its pretty easy to figure what is half way, but you always have to go it seems about an extra 1/4 turn due to elastic bending in the tubes
Old Mar 7, 2007 | 03:43 AM
blackwagon's Avatar
"color blind kid"
Makers of the benders mentioned above? I've used a manual to build a bunch of stuff already but that was custom and can't be bought. I'm looking at the "JD2 Model 3" theres a model 4 on craigs list but the guy wants way to much, even if its barely used.
Old Mar 8, 2007 | 06:55 AM
Enigma97's Avatar
Yes that bender is very close if not the same model that we (BLUE2KSS and team) use at the shop. I also like that it can be operated by one person. And, yes, it is very predictable and when used correctly, makes mandrel bends with no surface marks.
-Joel
Old Mar 8, 2007 | 11:01 AM
nightmare306's Avatar
the jd2 is made by JD squared up here in ocala. very good benders. very easy to operate, and great bends.
Old Mar 8, 2007 | 02:59 PM
blackwagon's Avatar
"color blind kid"
Where do you guys buy your materials?
Old Mar 8, 2007 | 06:01 PM
killerMikeD's Avatar
Lethal Fabrication.com
i have the jd2 model 3, Works great, havent had any problems yet!
Lethal Fab
Old Mar 8, 2007 | 10:38 PM
BLUE2KSS's Avatar
Mechanical Engineer
Aircraftspruce is where we get all our tubes, but be aware they are a bit on the expensive side
the tube bender says Pro Tools on it, they are local to Brandon. I can get the number if you would like, or search it on google, im sure they have it on there
Old Mar 9, 2007 | 06:50 PM
Jordan Y.'s Avatar
15 seconds EXHILARATION
What kind of price range are you looking at for these manual benders on the used market? Are they only capable of mandrel bends on shallow angles or can you get a mandrel 90 out of one? What size/thickness tubing are they capable of bending?
