Chassis & Suspension Tech Cages, braces, suspension set up and more
air cylinders
Old Mar 1, 2007 | 12:33 PM
CB'S CIVIC's Avatar
GANGSTER LEANIN CIVIC
Default air cylinders
i have a 94' civic with air cylinders.i'm having problems with my cylinders.if i lower the car all the way down the driver rear cylinder will slowly raise itself up little by little.in a matter of a minute or so it'll be all the way up.i need help.thanks.
Old Mar 4, 2007 | 10:06 AM
killerMikeD's Avatar
Lethal Fabrication.com
What type of valves are you running? Sounds like one one the fill valves is leaking back into the cylinder.
Lethal Fab
Old Mar 20, 2007 | 03:51 PM
surealconcepts's Avatar
SUREAL CUSTOMZ
i had the same problem lol i thought it was my valves but some how it was the cylinder... but in your case it sounds like one of the valves ... make sure there not backwards mean the exaust hole of the valve...
If you need any paint and body work please feel free to contact us: 727-698-6976
www.surealcustomz.com
