Chassis & Suspension Tech Cages, braces, suspension set up and more
chassis bracing
Old Feb 28, 2007 | 06:21 PM
jlude90's Avatar
aspiring luder
Default chassis bracing
i want to make some lower chasiss braces, but i have questions
first off what materials should i use, keep in mind i want ridgidity, but with cost/weight takin into effect, i guess cost being more of a factor
Cusco uses high tensile aluminum, should i get some cheap flatbar and fab up a model and bring it to a pro welder who can weld aluminum, or whatever material is best
Old Mar 1, 2007 | 05:31 AM
Enigma97's Avatar
I really don't see the need to custom fab expensive aluminum when steel tubing will work just fine with only a slightly lower tensile strength per weight. Running triangulated tubing to your suspension members will give the largest increase in torsional rigidity. Try to run the tubing as perpendicular as possible to the mounts so most of the force is loaded in the steel in compression/tension. Putting tubes in bending severely decreases the frames rigidity. I wouldn't worry about using aluminum, especially if you can weld steel yourself. Welding aluminum is not easy, and welding aluminum to steel is even harder.
-Joel
Old Mar 1, 2007 | 03:39 PM
jlude90's Avatar
aspiring luder
why would i want it perpendicular?
wouldn't 45s be better?
and do they sell triangular tubing locally?
Old Mar 2, 2007 | 06:09 AM
Enigma97's Avatar
Basically, you want all of your loading to be in either compression or tension. If you have a tube that is welded (or bolted) to the frame at your control arms at a 45 degree angle to the compression/tension forces from the control arms, half of the forces will be put into the tubing in bending and half would be in compression/tension. Since tubes are stronger in compression/tension than in bending, it is preferred to have the tubes acting in the same direction as those forces. Perpendicular might not have been the right way to put this, but, in most cases, you want to tubes running lateral between the right and left side control arm mounts. The triangulation tubing doesn't need to be real beefy because those tubes won't see that much loads. Think of a 4-point strut tower bar and the size of the main bar compared to the firewall support bars.
Aircraft Spruce is where my team buys most of their metal, but that's in Cali and shipping charges for small amounts of tubing probably outweigh the amount of tubing that you're looking for. I really don't know a good place locally.
For tubing, I would just run round carbon steel. Depending on how stiff you want to make it, 1"x.065 to 1"x.095 is probably what you're looking for. For the traingulation, 1"x.035 will work.
-Joel
Old Mar 2, 2007 | 01:55 PM
jlude90's Avatar
aspiring luder
oooo, i gotcha about compression and tension, good info thanks
