Banner post from FFA
You need a Focus up on that bizitch.
They all look good though my favorite is the one with Craig and Denises car...followed close in second by the CRX with the Ferrari emblem.
I like the skyline in the background as well however it wont look right when placed on the page. if you look at the top of the page on a high res monitor you will see that the image does not go all the way across and there is a table set up to the right with background colors set to match the image.
another fucking labor of love which has both import and domestic
Damn Justin Good Job man! I like it.
Craig no that wont work. Try taking the sky out of the skyline and just use the buildings the color of the sky blending with the blue is the only thing holding back your graphic. Trust me there is no way to make it blend in with the page the graphic is 775 pixels wide (optimized for 800x600) then the page is using a background image to fill in to the right if someone is using a higher screen resolution or someone posts a pic that makes the screen wider than it should be example notice how the image seams to keep going when you scroll right? that is actually just the background image not the banner image.
jeeze I need to get some sleep!
Current Active Users - There are currently 1 member(s) and 0 guest(s) on TampaRacing.com.
speed_daemon1
speed_daemon1
