Moving 94 Mustang Cobra-Fully Built/Needs Engine Work/$6500 obo (Made 520rwhp on 17Lb
or I will part the car out-$shell by it self Ill take $5k if i split the car up
HERE IS THE DEAL, I BLEW THE DRIVER SIDE HEAD GASKET IT WILL NEED TO BE REPAIRED CAR WILL STILL START UP N RUN STRONG AND WILL TAKE US ON A 3 MIN CRAZY TEST DRIVE TO GIVE YOU A TASTE OF THIS MONSTER. I NEED THE CASH I HAVE OTHER CARS ,BUT ITS TIME TO FINISH OTHER PROJECTS IT WAS DRIViNG PERFECT A WEEK AGO ITS MY FUALT GASKET BLEW IF NOT SOLD THEN ILL FIX IT NO BIG WHEN I CAN GET SOME TIME.--if i do not get my asking price or within range you will not get the $3500 turbocharger..
DO NOT MISS THIS CHANCE TO OWN A SICK CAR FOR CHEAP BECAUSE OF MY STUPIDITY
Windsor factory block 306 stroker 30 over
Je pistons
Eagle rods
Studed Block
Eagle crank
Arp Head studs
Arp intake manifold Studs
Arp Rod bolts
Arp Main Bolts
Ford bearings
High volume mellings oil pump
New timing chain dual roller
New water pump
Stage 3 turbo crower cam custom grind for this car
Aluminum svo stage 3 heads-full blown port n match setup
Stage 3 ported upper and lower intake cobra
Act stage 3 clutch tight clutch
Crower lifters hydrolic
Crower push rods custom length
Crane roller rockers higher lift
Crower valvetrain springs and retainers (titanium light weight)
Bronze guide seals
65 lb injectors ford racing(ranges out to lil over 700 cc of fuel)
255 fuel pump walbro
Ported tb
Racing maf custom built in the pipe
New factory radiator
Oem large electric fan
Tuned by vanquish at 519rwhp on low boost with 490lbs torque(motor good for 800rwhp..)
transmission
tremmec 3550 built with carbon gears
act pressure plate 2600
6 puck unsprung disk
12lb flywheel
new slave
Audio
full mach 460 sound system sounds real nice.
Turbo kit
Gt42rs Garret turbo (dual ball bearing)
dual vibrent steel feed lines and fittings
Custom intercooler piping hand made stainless
Tial 50 mm bov
tial 38 mm wastegate
Bbk turbo manifolds shorties
Custom oil feed and return
1000hp inter cooler bmc
Dyno tuned by Drew at Vanquish(soon to be retuned on 700hp)
Ford racing boost gauge
aeromotive fuel pressure regulator
custom relocation battery
Autometer fuel pressure gauge
brakes-
upgraded big brake cobra kit
dual piston caliper
drilled rotors
high end ceramic pads
Body real svt cobra
Cobra wing
Cobra nose
Cobra rear
Cobra R keenan hood
Cobra headlights
Cobra tails
Cobra big brake kit
Cobra r wheels
Beautiful factory red paint o my very sexy
Interior
Factory cobra interior
Tan leather fronts nice shape
Tan leather rear
Cobra airbags
Cobra original badges
there is so many thing you would not expect this car to be the way it is,but I have another cobra engine that will be installed and car will be sold a bone stock cobra for $7k your choice.
This car is disgusting clean and fast $30 k under the hood alone a real cobra 52,000 original mileage.
727-859-3901 carfax for verification
Je pistons
Eagle rods
Studed Block
Eagle crank
Arp Head studs
Arp Rod bolts
Arp Main Bolts
Ford bearings
New water pump
Bronze guide seals
Ported tb
transmission
12lb flywheel
new slave
Audio
Turbo kit
Tial 50 mm bov
brakes-
dual piston caliper
drilled rotors
Body real svt cobra
Cobra wing
Cobra nose
Cobra rear
Cobra R keenan hood
Cobra headlights
Cobra tails
Cobra big brake kit
Cobra r wheels
Interior
Tan leather rear
Cobra airbags
Luis-DC4
For Sale/WTB Honda & Acura
30
Jan 6, 2012 09:17 PM
jayofbrandon
32
Jul 19, 2011 07:05 PM
