Pair 15'' Kicker L5's In Max SPL Custom Box
These are a pair of the L5 series Solarbaric 15 inch Subwoofers in a Custom Max SPL Huge Box as you can see in this pics. Made for a Van/SUV bigger vehicles. These Speakers and Box will blow you away with Power with the right amp. If you need an amp for them I can find them as well. These are the Specification's on the L5's
Kicker 06S15L5-2 Features and Specs
Power Handling Watts Peak (RMS): 1500 (750)
Frequency Response: 18-100kHz
Sensitivity: 88.8db
Resonance Frequency: 24.0Hz
Nominal Impedance: Dual 2 ohm or 4 ohm
Total Q-Factor [Qts]: 0.428
Equivalent Volume [Vas], ft3 (L): 7.92 (224.36)
Outer Frame Dimension, in (cm): 15-5/8″ (39.7)
Mounting Depth, in (cm): 8-12″ (21.6)
Patented square woofer technology
Ultra-rigid SoloKon with constant back bracing
T-cut top plate for wider magnetic field, increased thermal efficiency
Progressive-roll, poly-cotton spider
Spring loaded terminals
Voice-coil wire to 428 degrees F
Rear foam gasket on stamped-steel basket with perimeter venting
Min Sealed Box Volume(cubic feet): 1.5
Min Vented Box Volume(cubic feet): 3
Please Call Bob @ (727) 608-0390 At anytime. I am Asking 1,000 for the box and speakers. Which I know seems high but if you know your Boxes this Box is very Expensive and Custom made for these Speakers to Perform at there maximum ability. If your looking to wake up the neighborhood these are the things to do it. Thanks, Bob.. Just call me we can Discuss Prices.
Sensitivity: 88.8db
