Cleaning out my room- subs, boxes, legacy amp, wires
I've got a bunch of stuff i've had sitting in my room for awhile and figured its time to get rid of it.
-American Legacy 2000 watt 2-channel Bridgable amp- works, sounds great, has a LOT of power. Had this hooked up to the pyle and it POUNDED, may have been a bit too much power for the sub in fact. All terminals and everything intact, nothing stripped, bent, broken, etc. $100
-15" Pyle Blue Wave sub with box- box measures 15" deep by 17" high by 17.5" wide- sealed, with quick-connect terminals on the back, carpeted, made of 3/4 MDF- very sturdy and well sealed. Sub seems not to be working but may be repairable. $40
-Panasonic df100 head unit- 40wx4, works perfectly, sounds great. Display is a bit dim, but is still visible and all buttons and everything work. Looks to be a nearly new wire harness on it. $20
-Rockford Fosgate P2 12" subwoofer- works perfectly, NOT blown, can demonstrate. This sub POUNDS, just don't need it anymore. $40
-Box for 2 12" subwoofers- about 1 cu per side, separate sealed chambers with quick connects on the back, carpeted, 3/4 MDF- $20
-Scosche FAI-3a- used to convert high inputs to RCA's, or to use an aftermarket head unit with a factory amplifier- $10
-Scosche 6 ga fuse holder with 3 feet of 6 gauge wire- $10 (i also have about 2 ft of 6 ga black ground wire, for $5)
-7 feet of 4 AWG wire- $10
-15 foot long High Performance RCA cables- made to transmit a clearer, louder signal from the head unit to amp- $10
-Vampire RCA cables- extremely high quality, i paid $20 apiece for these, just moved where my amp was mounted so can't use them anymore. One is 5 ft the other is 7 ft- $15
-20" Pulsing Neon bar- blue- pulses with music, with adjustable sensitivity- 12v power and ground, has switchable pulsing and constant on modes- had this in my car for awhile and it is BRIGHT, gets a lot of looks at shows and hangouts and such. $20
All prices are OBO. Will offer a package deal if you need more than one thing. Located in the spring hill/brooksville area. May be open to trades, mainly looking for an ipod touch (preferably 2nd or 3rd gen 8gb, in good shape) and cash. Also need an alpine double-din head unit and a pair of 6.5" type R components. But let me know whatcha got! Reply or PM me (PM preferred), or Call or text (727)271-6370 i work every night this week from 4-11 but if you text or leave a message i will text or call back ASAP.
