Car Audio For Sale Strictly Car Audio / ICE related For Sale/WTB threads.
system forsale
Old May 6, 2007 | 10:40 AM
chondacrx's Avatar
gangster
Default system forsale
i'm getting a bigger and better system so i have this for sale
audiobahn 2 aw1000q 10s in a box
Main Features:
120 oz. Double Stacked Strontium Magnets
Power Handling: 800 watts R.M.S.
Frequency Response: 20Hz – 500Hz
Efficiency: 95.6dB
PHAT 1.75" EPDM Rubber Surround
Spun Aluminum Cone
3" 4-Layer ASV Voice Coil
Dual 6 Ohm
3 Ohm or 12 Ohm Operation
Mounting Dimensions: Depth; 5" Hole; 9 1/4" Diameter; 10 7/8"
Multi-connect Lug Lock Terminals
ALUM series subwoofers are designed for those who crave the ultimate in sound quality. The lightweight aluminum cone has the strenght necessary for deep and powerful bass while allowing it to be faster than a speeding note. This is the true definition of what tight bass is. Dual 6 Ohm voice coil give you the ability to run them in three's and really, who can say no to a threesome?
Audiobahn a3201t amp
Audiobahn Class A/B MOSFET amplifiers are the hottest looking amps around. With the Cobalt blue illumination, LED voltage and status displays, high gloss chrome finish, and trademark flame fan covers, these amps are anything but subtle. Best of all, there’s plenty of power packed in the internals to back up the hot look. The unregulated PWM (Pulse Width Modulated) power supply allows these amps to put out more power when the input voltage is higher – a perfect match to Audiobahn stiffening capacitors. Thanks to the built-in cooling fan and 3-way protection circuitry, stability is no problem. The Class A/B Series includes audiophile features such as variable 18dB/octave high pass (50 - 750Hz) and low pass (30 – 120Hz) crossovers and a defeatable 18dB bass boost at 45Hz. There's even built-in variable subsonic filter to protect your subwoofers during “intense crank it up” sessions. Amp Specifications RMS Power @ 4 Ohms: 300W x 2 * THD at 4-Ohm RMS Power: 0.02% * Bridged RMS Power @ 4 Ohms: 840W x 1 * Speaker Level Inputs: no * Preamp Outputs: yes * Built-In Crossovers: HP/LP * Bass Boost: 0-18 dB * Frequency Response: 10-40,000 Hz * Signal to Noise Ratio: > 100 dB
1.2 farad cap
kicker crossover
amp kit and wires for the cap
amp sells for 379 now
heres my number 863-510-7816 chris
make offers or will trade for stuff for a 00 civic si or rims to fix it
Old May 6, 2007 | 03:34 PM
chondacrx's Avatar
gangster
Old May 8, 2007 | 07:21 AM
chondacrx's Avatar
gangster
Old May 9, 2007 | 10:49 AM
jimmybrown's Avatar
how much are you looking for???????
Old May 9, 2007 | 12:46 PM
chondacrx's Avatar
gangster
350 for everything
Old May 9, 2007 | 04:21 PM
chondacrx's Avatar
gangster
Old May 12, 2007 | 07:41 AM
chondacrx's Avatar
gangster
Old May 13, 2007 | 06:14 AM
chondacrx's Avatar
gangster
Old May 13, 2007 | 09:44 AM
chondacrx's Avatar
gangster
300 firm
Old May 14, 2007 | 02:11 PM
chondacrx's Avatar
gangster
