BMW / Mercedes Tech Germany and its finest
need help
Old Jul 4, 2012 | 12:32 PM
evansteger's Avatar
Default need help
hey guys i was just wondering if the 96 318is engine will work with a 92 318i with out any mods? This is my first bmw so i dont know much..thanks for the help
Old Jul 13, 2012 | 01:17 AM
Ls_[eg]hatch's Avatar
mowchowbrowncow
don't hold me to it but Everything i would imagine is the same Minus the Ecu. They are pretty much identical motors Except the 318i motor is a 8valve motor & the 318is is a 16valve motor
If anything the most i would imagine the swap to take would be Motor,Wiring harness, & Ecu. I would imagine the trannys are the same. Hope this helps out I just don't know much about the 4 bangers & swaps.
Try a more bmw related site
Old Jul 16, 2012 | 03:50 AM
bam2002's Avatar
The 92 is OBD1 , the 96 Is OBD2. so the intake, sensors, wiring and ecu are different. Unless you swap the car over to OBD1. There are articles on the web on how to do this. 1996 I think is the 1st year they went to ODB 2 on the 4 cyl.
Also I recall hearing the early engines had a different and crank and timing chain set up.
