UUC D-Force 17inch Light weight wheels
I have a non staggered set, 17inch black with polished lip brand new!!! Never mounted only kept in show room. I want them gone ASAP someone make me an honest no bull shit offer and they are yours!!! Retail is 249.99 a wheel plus shiping!!
How D-Force wheels are made:Step 1Step 2Step 3Step 4
The center area of the wheel is first cast in a low pressure mold, then removed and spun on a CNC machine where it is pressed, heated, and spun simultaneously, resulting in a semi-forged finish that forces the aluminum in the barrel area of the wheel to be thinner yet molecularly more dense, allowing more strength from less mass. And we all know that less rotating mass is the name of the game in high performance.
SizeWeightPrice17x8.5
17x9
17x9.5
18x8.5
18x9
18x10
16.2 lbs
16.4 lbs
16.6 lbs
18 lbs
18.2 lbs
19.2 lbs
$249.95
$259.95
$259.95
$299.95
$299.95
$309.95
GALLERY
Specs on the wheels are shown below. They come in 17inch and 18inch with a 8.5 standard width and 9inch for $10 more on the 17's. All colors are the same price. I currently have 17 x 8.5 in the black with polished lip and 17 x 8.5 anthracite with 17 x 9inch for a staggered set up. Let me know if anyone is intrested they are $235 a wheel for the standard 8.5 for 17's and +$10 for the 9inch and the 18inch are $285 a wheel for 9inch width and +$10 for the wider 10inch
applications: 1992 - 2008 (E36 E46 E91 E90 E92)
Ultra-lightweight wheel in a 17 inch size for your 3 series.
The perfect track or street wheel for fitting wide rubber under your car. At just over 16lbs. each on 17", you'll have a hard time finding a better performance wheel for the money. 41mm offset, flow-formed for superior strength, and fully tested for impact and crack resistance. Available in 3 sizes, and three finishes; silver, anthracite or black with machined lip. BMW roundel center caps are also available.
Recommended tire sizes:
17 x 8.5" (16.0 lbs) - 235/40 - 245/40/17
17 x 9.0" (16.6 lbs) - 245/40 - 255/40/17
These wheels can be used on 1992-2008 - 3 series, including the following BMWs:
E36 - 1992-1999 - 318i, 318is, 325i, 325is, 328i, 328is, 323is, and M3;
E46 - 1999-2005 323i, 323Ci, 325i, 325Ci, 328i, 328Ci, 330i, 330Ci;
E90 - 2006+ sedan - 325i, 328i, 330i, 335i;
E92 - 2007+ coupe - 328i, 335i.
The center area of the wheel is first cast in a low pressure mold, then removed and spun on a CNC machine where it is pressed, heated, and spun simultaneously, resulting in a semi-forged finish that forces the aluminum in the barrel area of the wheel to be thinner yet molecularly more dense, allowing more strength from less mass. And we all know that less rotating mass is the name of the game in high performance.SizeWeightPrice17x8.5
17x9
17x9.5
18x8.5
18x9
18x10
16.2 lbs
16.4 lbs
16.6 lbs
18 lbs
18.2 lbs
19.2 lbs
$249.95
$259.95
$259.95
$299.95
$299.95
$309.95
GALLERY
Andrew Congleton
-Lutz Performance Automotive
PH: 813-949-3540
Cell: 703-314-6511
Andrew@lutzperfauto.net
17510 US HIghway 41 N
Lutz, FL 33549
Andrew Congleton
PH: 813-949-3540
Cell: 703-314-6511
Lutz, FL 33549
Solllllldddd
Andrew Congleton
PH: 813-949-3540
Cell: 703-314-6511
Lutz, FL 33549
Andrew Congleton
PH: 813-949-3540
Cell: 703-314-6511
Lutz, FL 33549
