questions about M50 mani swap
im in the market now to pick up a M50 intake mani. what all am i going to have to replace when doing the swap? im sure a intake mani and throttle body gasket. are there any other gaskets i should replace? also heard its a good mod to add the throttle body spacer too.
any help guys who have done this swap? thanks
98 E36 ///M3 Sedan
07 Civic Si Sedan
98 E36 ///M3 Sedan
07 Civic Si Sedan
m50manifold.com, and there is tons of DIY online.
yeah, they are $440 fr everything. im hoping to get a mani cheaper off someone online and then ordering the kit for them.
how much would your shop charge to install it? would you need the kit or you able to install it without? i can supply the mani
98 E36 ///M3 Sedan
07 Civic Si Sedan
98 E36 ///M3 Sedan
07 Civic Si Sedan
Unless you went out and sourced the parts (kit yourself) then I would need the kit, I dont have the time to go running around to find the little connectors and such that is needed.
Install would be about 2 1/2 labor.
PM your labor charges. i can supply the kit also
98 E36 ///M3 Sedan
07 Civic Si Sedan
98 E36 ///M3 Sedan
07 Civic Si Sedan
