Kfx 700!!!!
Old May 21, 2003 | 06:05 PM
svtjesse's Avatar
Default Kfx 700!!!!
All I have to say is DAMN, just got to build and ride one at work today, 700cc of pure, non gear shifting madness, out of all the 4wheelers I have rode, I have NEVER had one just pull up the front end out of power alone, but the kfx did, by far the baddest stock 4wheeler, some specs from kawi's site....
Engine: Liquid-cooled, 90-degree, 4-stroke V-twin Valve system SOHC, four valves
Displacement: 697cc
Starting system: Electric
Bore x stroke: 82 x 66mm
Compression ratio: 9.9:1
Carburetion: (2) Keihin CVKR-D32
Ignition: DC-CDI
Transmission: Kawasaki Automatic Power Drive System with forward, reverse and neutral
Final drive: Shaft
Frame: Double cradle, racing type, high-tensile tubular steel
Suspension, front/wheel travel: Dual A-arms, coil-over shocks/9.25 in.
Suspension, rear/wheel travel: Linkless swingarm, upside-down gas-charged shock, dual-rate spring/7.9 in.
Tires, front: ITP Holeshot AT22 x 7-10
Tires, rear: ITP Holeshot AT22 x 11-10
Brakes, front: (2) Dual-piston disc
Brakes, rear: Sealed oil-bathed multi-disc
Overall length: 78.0 in.
Overall width: 47.1 in.
Overall height: 46.9 in
Seat height: 33.5 in.
Wheelbase: 50.8 in.
Ground clearance (at center of chassis/at rear axle): 9.6/6.3 in.
Lighting, headlights: (2) Halogen 12V, 45W headlights, 5/21-watt taillight/brake light
Dry weight: 516 lbs.
Fuel capacity: 3.2 gal.
Instruments: Neutral indicator light, reverse indicator light, low fuel warning light, low oil warning light
Colors: Kawasaki Lime Green, Blazing Orange
Old May 22, 2003 | 08:20 AM
Nate's Avatar
TR Balla Donor Supreme
bad ass 700CC!
