I turn the key on and nouthing works but neutral light
sonny
Have an 06 883. Sometimes I turn the key on and nouthing works but neutral light.the Speedo stoped completely about 3 months ago nouthing on it no lights miles or the hand. I pulled every connection apart and put electric grease on them tighten all battery cables no luck. I was talking to someone and they said many the ecm. I looked this thing up but I can’t find out what it dose or what it controls also something about a replay and a circuit breaker. Please help
Customer Service
Hi Sonny. Make sure that you are installing/tightening your negative battery cable on your battery with the opposite end disconnected from the frame.
If you are not, your negative cable will loosen as you slide the battery in.
Also, try checking for stored diagnostic trouble codes.
Elias
I have a 2008 street glide. It turns on but it only goes 20 mph does not go any faster change gears and nothing changes. Any suggestions
Steve j
Have a2001 Fatboy carbureted. It dropps the front cylinder, changed plugs and wires, changed coil and all was fine. Ran good for a month, drove to work today, ran fine, after work was back to the rear cylinder only firing. Now what????
Customer Service
Hi Steve. Need to verify weather or not you have spark @ the front cylinder.
If you dont, and you already replaced coil, plug wires & plugs; you may have a bad ignition module.
If, however, you have spark but the front plug is fouled out; your issue is not electrical
Charles Lennix
ok Steve I will check it out when i get off from work in a lil while. the bike was running fine and all of sudden i started running real bad. I had to get the trailer to take it home
Charles Lennix
my 2005 15th yr anniversary fatboy is losing power,decelerating,and misfiring. I can’t figure out what’s wrong.I need help please!!!!!
Customer Service
Hi, Charles. Start by checking for trouble codes and do a full charging system test.
09-26-2023 11:41 PM
07-03-2021 03:43 PM
doefat07
03-30-2007 08:48 AM
