Bike sat 4 months..front breaks gone
my 2004 gsxr 600 sat for about 4 months,now my front breaks barely work.I tryed bleeding them,nothing happens,they worked perfect before it sat for so long...any ideas?
1996 Prelude
2004 GSXR 600
1996 Prelude
2004 GSXR 600
What does this do?
I just put new front end on my bike last night and when I left my rear brake didn't work at all barely , was very dangerous, after holding it down and heating up the disc it started responding a little better.
Only possible thing was when I was cleaning my chain w/wd40 I might of missed and hit the disc, but I'm almost sure I didn't..
Thinking something is wrong don't know what, might try zip tieing it if I knew what it does
I'm guessing it just forces air out of the lines?
What does this do?
1. why the hell are you cleaning your chain with WD40?
2. Holding down the brake and thinking your heating up the rotor will actually warp the rotor
3. Zip tie trick only helps spongy or dead brakes from sitting. Doesnt bypass bleeding them
4. back to the WD40 it seems since you didnt mess with the rear except "cleaning your chain" would narrow down the problem.
I use wd40 to clean my chain... all the lubrication is sealed in todays chains.
The spray on gooey shit is only good to trap dirt and help grind your sprockets to death...
Hydro...
Replace the pads, and bleed your brakes... And change that shitty ass D&D slipon you have on the bike... trust me it does not sound cool at all...
Hydro...
I don't suffer from insanity, I enjoy every minute of it
i use wd40 to clean my chain but i also spray the gooey shit but very lightly.
And you have experienced this 1st hand?
I'd like to see how this is scientifically possible.
Anyways... Been using it for years with no problems... i must be getting WD40 immune O-Ring chains without knowing...
Its a petrolium based product that makes rubber swell and eats away at the rubber and metals....
Motorcycle Chain Lube Maintenance
Does WD40 hurt o-rings? A test.... - ThumperTalk
Scroll to bottom of this
Motorcycle Chain Lube - webBikeWorld
I can go on and on if you would like...
