frame sliders won't come off
Old Aug 24, 2008 | 12:58 PM
suprapimpa's Avatar
Default frame sliders won't come off
I installed them about a month ago it was easy took the bolt out installed the frame slider. Now a month later I go to take off my fairing and I have to remove the frame slider first so I bust out the socket wrench and it turns about 4 turns then locks up and it won't turn anymore. I have no clue what's wrong I read a bunch of how to's and the instructions before I installed it and its worked fine until I tried to take it out anyone know whats wrong?
Old Aug 24, 2008 | 01:15 PM
???'s Avatar
Capt."Howling Mad"Murdock
yeah, you didn't put any anti seized on it.
if you haven't snapped the bolt off yet or stripped it out. find some pb blaster. spray it on, wait a while, spray some more. tap it some to shock it.
then after a few mins or hours of that, try tighten it back up. it should go back in some. then spray more and work the bolt in and out as much as it will give you. don't force it.
with luck it will come off.
Old Aug 24, 2008 | 01:18 PM
OrOr's Avatar
How fast officer?
Sounds like the threads are screwed. If the spray doesn't work, it's prolly best to remove it with an impact wrench and hope the bolt doesn't break. You may have to get a new bolt and rethread the hole.
Old Aug 24, 2008 | 01:32 PM
???'s Avatar
any good impact will snap it like a twig.
if it won't come out, i'd just leave it and work around it lol.
Old Aug 24, 2008 | 02:32 PM
suprapimpa's Avatar
fuck me
Old Aug 24, 2008 | 03:04 PM
J@meson's Avatar
Resident Ginger Kid...
yep shoulda used anti seize
2005 Joe Gibbs Silverado # 0396
1988 Monte Carlo SS 5.3/T56 and too many mods.
2003 Honda 954RR
Old Aug 26, 2008 | 01:44 PM
wolfey971's Avatar
first off, what yr bike is it? there are other options to get the plastics off, on my old bike, I cut a hole in the plastics large enough to fit the sliders thru, it became a pain cause I was always removing them to do anything to the bike.
if you do it with precision, it wont look bad at all, use your imagination when it come to cutting the hole. ask questions, measure 4 or more times before cutting, and dont use the first tool you find laying around to cut it.
as far as getting the bolt out, you might have to get a new set of sliders, but I would cut the slider off, take off the plastics, and find some heat (torch) and work it out that way, you might try working it back and fourth, each time try and take it 1/4 turn past the last turn.
I would not recommend an impact, you can really mess things up that way, especially if you snap it off.
Originally Posted by WSideShow
I hate the Florida Gators ughhhhh.
'04 GSXR 750
I'm so far behind, I think I'm first
need tires (take offs)? PM me
need a deal on a track day? PM me
disclaimer: I sell used tires (take-offs), these tires have been used at Jennings, Homestead, etc. (road courses for those that dont know) therefor these tires are more used up on the sides than in the middle,
Old Aug 27, 2008 | 03:13 AM
chiefin's Avatar
+1 this stuff is the shit... u can find it at any a/c store or lowes
Old Sep 6, 2008 | 04:37 PM
suprapimpa's Avatar
I used pb blaster and its still sounds like it stripping the shit out the bolt any other suggestions. I might just take it to a shop it seems like everything i try to fix looks so easy on paper and then i just go and fuck it up
Old Sep 6, 2008 | 07:46 PM
suprapimpa's Avatar
psych it just worked i had to wait alot longer than i thought thanks for the advice guys i probably would have stripped it to shit getting frustrated
