Random Questions
Old school TR member
on
Random Questions
So my first front tire on my bike wore really weird
Explanation:
Every 2 inchs or so there was a bald spot to the right of the middle of the tire and between each bald spot those two inchs were a slight bump. It rode perfectly fine though.
So on to the second tire it seems like its wearing the same way. Ive always felt that my left arm has been slightly extended more when riding, so I was looking at the forks today when riding and the left one seemed slightly more forward than the right. Could that be the reason for the tire wearing like this? Should I just loosen the triple clamp and adjust it to see if that solves the problem?
BTW
I was just watching superbikes on speed and jason britton received a bike from kawasaki and the last three on the vin were 666 so he sent it back and got a new one. Anyone think I can pull this off since when I am going 66mph its @ 6k rpm?
Explanation:
BTW
on
No not really. I do way more wheelies on my brothers bike and his tire is fine.The forks are deff miss aligned I think when I bought it they tightned the triple clamp bolt down with the tire angled slightly, just thought Id see some other peoples opinions. Its rides fine though even when I take it out and rip through corners.
If its horizontal cupping then it could be bad shocks, diagonal cupping is usually toe.
This is from a cager though, just trying to help.
well if your top triple looks crooked when you're going straight then i would adjust it but if you do a lot of wheelies you will start to get flat spots on the front tire esp if you keep it up til the front wheel stops
**new sig coming soon!**
i've heard of it.. its real big on the zx10 boards right now because a lot of them are pulling to one side really bad. they are finding them not angled right and even one tube higher in the triple clamp than the other one.
post pics of the tire, it could even be pretty normal wear for that brand of tire. i know the older dunlops wear funny as hell to me.
on
thanks for the input guys
on
