water as fuel
In contrast to common assumptions, a hydrogen fire emits one-tenth the heat of a gasoline fire, and the explosive power of hydrogen is 22 times weaker than a comparable gasoline explosion.
Seems actually safer than anything with gasoline.
.Fear is the Mind-Killer.
Chicken Strips: It's a Goddamned Food Item.
.Treaty of Tripoli 1797, Article 11.
Originally Posted by C ME WRKD
Chicken strips? I see no grocies in that pic
http://iknow.iit.edu/download.php?file=450
your looking for the wrong thing. it may be be powerfull but any at all under your hood will set your car on fire.
you need to look up the conbustablity(sp) as in how easy it is to catch fire. gas is not very much at all. hell you can put a match out in a bucket of gas of you do it fast enough.
i think if you really want better mpg you should do something worth while. like research what tuning software is out for the car you drive and then pick up a wide band o2 and learn to turn your car.... along the way your own driving habits will change too. you will be suprised how much the factory tune can be improved on once you get the cat off and tune for it.
the factory is so hog tied by the epa that even the old 90 gm ecm's had a highway mode coded in them to make the car run at mid 16:1 and full egr once it was safe to run there. but the epa made them disable it by setting the coolent enable temp to 255*C because they said it was bypassing the cat and thats not allowed.
just enabling that option along is netting most people over 4mpg in mixed driving. more to be had with a few mods.
plus your learning a useful skill along the way... which seems much better to me.
