Need Help On Sprockets !!!
Old Nov 15, 2007 | 03:15 PM
Frankie Figs's Avatar
Too Much is ALMOST Enough
Go down 1 in the front. Wheelies are all in the rider. I'm 270lbs and I can wheelie a stock gsxr 6 without an issue. I was on the back tire on my friends 06 600 when the odometer rolled over 20k miles
Old Nov 15, 2007 | 03:58 PM
GSL_SE's Avatar
so just one down in front and nothing to the rear ?
Old Nov 15, 2007 | 04:06 PM
Thats what I would do. A couple guys around here are running -1/+2 and I honestly think their bikes are slower now. Either -1 OR +3, -1 in the front is equal to +2.6 in the rear and since you cant do +2.6 on the rear +3 will give a hair more acceleration than -1 up front will.
Old Nov 15, 2007 | 04:36 PM
GSL_SE's Avatar
ok sounds good man thanks alot vortex sounds good ... everything i have is vortex .. and its been pretty reliable so far
Old Nov 15, 2007 | 05:50 PM
ar_audio's Avatar
I went 1 down and two up. But you have to find out what the best ratio is for your bike. I have a daytona 600 and a 3.14 ratio is the best. So that is what i got.
Originally Posted by Drama Llama
I think the op's mom should've swallowed him when she had the chance .
Old Nov 15, 2007 | 06:29 PM
Urban-RR's Avatar
Go Getta
when you get a sprocket look into a chain. You might have to add a few links if you keep old. But id just get a new chain. my .02
30 min before i get off for an hour then back to work at a different shop blaaaaah
RIP John P
USMC
Done Sir Done
Old Nov 15, 2007 | 06:32 PM
  #17 (permalink)
Urban-RR's Avatar
Go Getta
-1/+9 will lost about 25% of top speed not sure how much of the percentage is correct so dont quote me on it. Plus Speedometer will be off too.
RIP John P
USMC
Done Sir Done
Old Nov 15, 2007 | 06:33 PM
  #18 (permalink)
Capt Insano's Avatar
I just changed my setup from -1/+2 to -1/Stk...I like my new setup way more, the gears were to short before...You can easily wheelie the bike w/ -1 in the front...Good luck to you
Old Nov 15, 2007 | 07:42 PM
  #19 (permalink)
sohc.vtec.steve's Avatar
supercharged sohc ftw!
thanks everyone by what im told i should just go one down in the front so im goin to try that out ...
Old Nov 15, 2007 | 07:46 PM
  #20 (permalink)
GSL_SE's Avatar
